............What is your truck rated to tow? What about the 550?fordt said:My brakes are bigger, and I believe the frame is heavier.
My 450 could have came from the factory with 4.30wftree said:Gearing is my only *****. 4.88 are rediculous. I am re-gearing mine shortly to 4.30.
Then why is my front axle so much freakin wider than a 350?:shrug:kblackav8or said:Front end is still a dana 60,
My truck has a 16000 lb. GVWRSAVAGESAM said:............What is your truck rated to tow? What about the 550?
In 05-06 they widened the front axle on the F-450/550s......can't remember why off hand though, or if there are other difference in the axle vs. a F-350 DRW...:shrug:fordt said:Then why is my front axle so much freakin wider than a 350?:shrug:
It is an option but most will come in with 4.88.fordt said:My 450 could have came from the factory with 4.30
The F450 has a 15,000 rating and the f550 can be 17500 or higher with a special package. The brakes are significantly bigger, stronger frame, larger axles in back, older F450 Dana 80HD and newer Dana 110 the F550 has a dana 135.
Gearing is my only *. 4.88 are rediculous. I am re-gearing mine shortly to 4.30.
wftree
