I was wantin to put 5in exhaust on my truck an i was wonderin were can i find some 5in pipe for my truck. If anyone knows anywere i would really appricate it. thanks alot.
:smoke "The Smoke Don't Mean It's Broke!"
early 99' F-350 ext cab, AEM intake, edge programmer but not for long. "Soon to come 5in exhaust with 7in tip"
If your makeing your own exaust system 5in is the norm for bigger over the road trucks so any truck shop shoud cary 5 in pipe and elbows.
yeah i didn't bout that it would be ok just to cut the cat off and run my 5in from there it would be ok or should i run a new down pipe to. i am wantin to run one 5in pipe and before i get to the rear diff. take an put a y pipe on there an put two 7in tips. that way it will look an sound good and im not to sure if anyone has that set up.
Like he said any good truck shop will have what you need, Or you can get 5" systems from several psd shops such as TYMAR or Northern Diesel Performance. You could buy a splitter and two over the axle pipes. Just cut the one for the left side and reweld the last part on 180 degrees out.
