Im looking at getting pillar guages and ive got a 4 pod. I was thinking about doing boost, pyro, Trans, and fuel pressure but im not sure what i need each guage to go up to for a 6.0? and suggestions?
Pyro-- 0-1600 deg
Trans-- 100-250 deg
fuel-- 0-100 psi
Boost 0-35 psi
These are for a mild set-up, if you plan on going with big injectors and turbo then you need to get a boost gauge with 0-100 psi. Hook up your boost gauge to the intake elbow, more accurate. For more accurate egt's install pyro pre-turbo.
Reactions: 06Harley350
