hey what kind of turbo should i use on my 98 24v 3500 5spd
after 150 injector edgejuice with attitude stage 2 cold air and a vp44:shrug:
It kind of depends on what you are going to use the truck for. I would look at the High Tech series turbos. Probably a quick diesel for the amount of fuel you will be running. You could also go with a SPS turbo from II.
hauling and pullin the sled
Hauling A-- or Hauling a trailer?
I would still go with a turbo in the 64/-- range. The 24v Vp trucks don't seem to spool the larger (66mm and larger) as well as a 12v or CR. The 64 should have good street manners and keep it cool.
Given what I just said, there are guys out there that drive with a 66/-- on the street. It would probably be the better turbo for sledpulling if you have the fuel, but I think you would lose street manners.
The 99 in my sig has a 62/14 and it is fun to drive on the street and makes good power. Can't really comment on the sledpulling, because in the 2 hooks with it we were severely traction challenged so we never really lugged it down. But for a daily driver it is awsome.
I like the new Garrett BB unit. They have are good ont he street cause of the fast spool up and are price resonably
about how much does the bb garrett turbo cost
They are a little cheaper than the High Tech Series turbos or SPS turbos. They tend to spool quicker because they are a ballbearing turbo. They are oil and water cooled and unless they have changed they have a 3" outlet. Some people don't go this direction due to the ball bearings and the outlet size, but I have no experience with them. What I have read is that the ball bearing turbos don't tend to last as long, and that once they start to go they won't limp along like the others.
