1 - 20 of 24 Posts
Looking for some options here before I mess the trans up. Lookin at ATS and Suncoast so far. Any thoughts???
99% of people with built trannies in the 6.4 run the suncoast........its a proven combo in the 6.4 and its what I plan on going with.
So If I just upgrade my torque converter and possibly TCM I should be able to run the 310 tunes no problem???
I have only had the truck for a few months now but have not been too hard on it. I'm just trying to get around this de-fueling issue right now, so if it's a slipping tranny hopefully a TQ should solve the majority of the issue (from the sounds of things anyway).
Spartan Diesel Tech
Your truck will not defuel from torque converter slippage.....only from internal clutch slippage. And this defuel will happen early on.....it will shift 1-2, 2-DEFUEL usually, or it can go 1-2, 2-3, 3-DEFUEL. That isn't the converter though, its the clutches slipping and a signal is sent via modules and the truck will defuel and fall on its face. If the truck is defueling on top end its fuel related, or tune related.
yeah, it's a definitely 1-2, 2-defuel. So i'd be lookin at a tranny on the way out more then likely!
2008 F350 Murdered out
What's PI ??
Im guessing a Precision Industries torque converter is what Aaron was referring to?
Im sure he'll elaborate more once he sees the question
Ford 6.4 it's just cooler
How does an extreme rebuild kit and converter sounds rather than the super duty rebuild? Would the addition of the shift kit from either kit require revised tunes? I'm planning on a converter, extreme rebuild kit, and billet input so can keep stock solenoids. Sorry to high Jack
Spartan Diesel Tech
Why not just get the super duty rebuild kit??? It has quite a bit more in it for less than $400 more.
Extreme:
Over Drive Upgrade
• 5 Alto Red Eagle Frictions
• Kolene Steels
• SCD Pressure Plate
• SCD O/D Piston
Intermediate Upgrade
• 5 Frictions
• Kolene Steels
Forward Clutch Upgrade
• Steels
Direct Clutch Upgrade
• 6 Frictions
• Steels
• SCD Apply Plate
• SCD Apply Piston
Low and Reverse Clutch Pack
• 6 Alto Red Eagle Frictions
• Kolene Steels
Shift Kit
SCD Solenoid
Super Duty:
Over Drive Upgrade
• Kolene Steels
• SCD O/D Piston
• 5 Frictions
• Kolene Steels
• Steels
• 6 Frictions
• Steels
• SCD Apply Plate
• SCD Apply Piston
• Kolene Steels
Also Included:
• TransGo® 5R110 Shift Kit®
• Pump O-ring
• Pump gasket
• Sump Filter
• By-pass filter element
• Custom SCD Direct solenoid
• New EPC solenoid
• SCD billet in line filter assures
solenoid protection from foreign material. Includes spin on filter and all parts needed for a easy install.
I have a suncoast converter and superduty rebuild kit, works good:)
But we don't need the upgraded solenoid, and the rest of it is filtration?
Discussion Starter #19
Anyone in Alberta know who does good tranny work and is willing to install this stuff? As of now, I personally have tuned down to the 210 (not fun) to save the life of my trans untill I can get all this done.
Highjack was good, lots of great info and stuff to consider.....
Rene G got his rebuilt here, i beleve dirty diesel did it for him.
1 - 20 of 24 Posts
