If the Y pipe is cracked would the boost pressure = 0 psi? I don't show any boost pressure and can't feel the turbo at all (no power). Is that the symptoms of a cracked Y-pipe or loose flange connection? Just want to be sure before I tear into taking the Y-pipe off, for a close up visual inspection.
I just had the drivers side up-pipe clamp off when I changed the turbo and it appeared to be ok, but I didn't look at it real close. The soot I saw is on the drivers side up-pipe, both turbo side and pipe side. It is possible, I didn't get the clamp fully tight after changing the turbo, or there was a leak before. I don't know.
The motor is completely stock, with all EGR junk still in place. No performance mods at all.
Thank you all for helping me diagnose this issue. You guys are great.
Dave
Dave
