Standard Claims List For Model Year 2005
1FTWW31P95EB66677 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-DEC-2004 31-MAY-2005 152002 USA 12 7M01 150102 * 18805 * A04 42 31900
AWS Claim Key: 4844160 Trx Code: E83 Labor Hrs: 0.6
Dlr Cd-Sub Cd: 02515 - * Name: PAUL MURREY FORD-MERCURY, INC. Ph: 972-9622151 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:18-MAY-2006 Doc #:06717951
Cust Comments: CK RADIO VOLUME CONTROL INOP
Tech Comments: DOES NOT OP PROP RR RADIO ASSY SENT TO VENDOR FOR PAINT REPAIR
1FTWW31P95EB66677 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-DEC-2004 31-MAY-2005 152002 USA 12 7M01 150102 5C3T 18C868 AF A07 42 31900
AWS Claim Key: 5286058 Trx Code: E83 Labor Hrs: 0
Dlr Cd-Sub Cd: 48915 - * Name: VISTEON AFTERMARKET - U.S. Ph: *-* St:MI Ctry Cd: USA Reg Cd: NA Repr Date:18-MAY-2006 Doc #:44359309
Tech Comments: REQUESTING DEALER'S P/A CODE 02515
1FTWW31P95EB66677 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-DEC-2004 31-MAY-2005 152002 USA 14 * * * * * * * 34693
AWS Claim Key: 5316724 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 02515 - * Name: PAUL MURREY FORD-MERCURY, INC. Ph: 972-9622151 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-JUL-2006 Doc #:06845341
Cust Comments: 59B01 ELIGIBLE FOR ONE TIME CUSTOMER ASSURANCE TEST DRIVE. SEE EMISSIO
Tech Comments: 59B01 CUSTOMER ASSURANCE TEST DRIVE REPLACE
AWS Claim Key: 5316723 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 02515 - * Name: PAUL MURREY FORD-MERCURY, INC. Ph: 972-9622151 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-JUL-2006 Doc #:06845340
Cust Comments: 05E15 EXHAUST PRESSURE SENSOR REPLACEMENT, ON BOARD DIAGNOSTIC SYSTEM A
Tech Comments: 05E15 EP SENSOR, CONNECTOR, AND RECALIBRATION
AWS Claim Key: 5316725 Trx Code: 05B32 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 02515 - * Name: PAUL MURREY FORD-MERCURY, INC. Ph: 972-9622151 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-JUL-2006 Doc #:06845342
Cust Comments: 05B32 DE GAS BOTTLE FILL LEVEL LABEL AND FLUID LEVEL ADJUSTMENT
Tech Comments: 05B32 COOLANT DEGAS BOTTLE LABEL INSTALLATION AND COOLANT LEVEL ADJUSTME
1FTWW31P95EB66677 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-DEC-2004 31-MAY-2005 152002 USA 14 6D01 011001 5C3Z 2562900 SAA S52 01 34693
AWS Claim Key: 5316726 Trx Code: E84 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 02515 - * Name: PAUL MURREY FORD-MERCURY, INC. Ph: 972-9622151 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:12-JUL-2006 Doc #:06845351
Cust Comments: REPLACE DRIVER AND PASSENGER SEAT BOTTOM COVERS (LEATHER CRACKED)
Tech Comments: CRACKING BOTH SEAT BOTTOM COVERS REPLACED IF FRONT
1FTWW31P95EB66677 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-DEC-2004 31-MAY-2005 152002 USA 19 2H01 030008 5C3Z 6K854 AA E41 42 39295
AWS Claim Key: 6761148 Trx Code: E72 Labor Hrs: 8.4
Dlr Cd-Sub Cd: 07589 - * Name: BRIAN TOLIVER FORD LINCOLN Ph: 903-8850502 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:21-DEC-2006 Doc #:04860901
Cust Comments: C S THERE IS AN EXHAUST SMELL IN CAB WHILE IDLING CK AND ADVISE
Tech Comments: Y PIPE BROKE. R AND R TURBO AND TRANS RO RPL PIPES, RETEST OKAY
1FTWW31P95EB66677 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 15-DEC-2004 31-MAY-2005 152002 USA 31 2E03 0304XX 5C4Z 9A543 B D02 42 70305
AWS Claim Key: 9109770 Trx Code: E72 Labor Hrs: 8.2
Dlr Cd-Sub Cd: 01637 - * Name: ELLIOTT FORD LINCOLN MERCURY Ph: 903-5723486 St:TX Ctry Cd: USA Reg Cd: NA Repr Date:06-DEC-2007 Doc #:07225902
Cust Comments: CUSTOMER STATES THE VEHICLE IS TURNING OVER BUT WONT START
Tech Comments: REPLACED HIGH PRESSURE PUMP AND IPR SCREEN GONE FROM IPR EEC TEST P2290 DIAG PINPOINT TEST CHECKED OIL LEVEL CHECK ICP SIGNAL DAT ALOGGER ICP 40 PSI MTIME TO PREFORM HIGH PRESSURE LEAKAGE TEST REMOVED VALVE COVERS TO TEST ALL OK REPALCED HIGH PRESSURE PUMP AND FITTINGS KIT RETEST ROAD TEST REPLACED IPR SENSOR THE SCREEN MISSING FROM END OF
