Riding solow on the Hog
1FTNW21F73EA13693
Thanks for the offer to do it
Thanks for the effort to do it
Thanks for the ability to do it
Thanks for the patience to do it
Thanks very much for doing it
Yer flippen awesome.
(No, Im NOT kissing up, I just want to be sure yall know I greatly appreciate this.)
:happymugs
OASIS RESULT:
1FTNW21F73EA13693
USA
EN
05/14/2009
15:37:16
FCXWS447
© Copyright 2002-2008 Ford Motor Company. All rights reserved.
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2003 F-SERIES BODY STYLE
F-250 CREW CAB 4X4 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
2F719N0A
WARNING MESSAGES
ARN MESSAGES
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
11/20/2002 BUILD DATE
07/26/2002 SALE MILEAGE
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0858 - USA 2004 NEW 84/75,000 EXTRACARE W/ROADSIDE ASSIST
STANDARD DEDUCTIBLE: 50 USD
OWNER NAME: VIRGINIA NELSON
OPTIONS:
EXPIRATION DATE: 11/20/2009
DISTANCE: 75,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 05409
ESP CONTRACT START DATE: 11/20/2002
OWNER OF VEHICLE MUST MATCH OWNER NAME ON OASIS FOR COVERAGE TO APPLY
For competitive make ESP part verification click here
WARRANTY REPAIR HISTORY
05/22/2008
DEALER: Jim Vreeland Ford
WARRANTY CLAIM NUMBER: 045331 ODOMETER: 103249M
LABOR OP
CONDITION CODE
CONDITION DESC
000 07S57A
C CAMSHAFT POSITION SENSOR INSPECTION AND REPLACEMENT
05/22/2008
REEQUEST REFUND FOR 07S57 RECALL
1FTNW21F73EA13693 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 26-JUL-2002 20-NOV-2002 171472 USA 13 7D07 17XXXX F4CZ 13466 A L26 42 22041
AWS Claim Key: 3352718 Trx Code: E83 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 07848 - * Name: ATASCADERO FORD Ph: 805-4669464 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-NOV-2003 Doc #:07400101
Cust Comments: RIGHT SIDE TURN SIGNAL AND BRAKE LIGHT OUT
Tech Comments: PERFORMED DIAGNOSIS AND REPLACED BULB. RECHECK AND NOW OK.
1FTNW21F73EA13693 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 26-JUL-2002 20-NOV-2002 171472 USA 13 5T01 * * * * * * 22041
AWS Claim Key: 3352717 Trx Code: 03B03 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 07848 - * Name: ATASCADERO FORD Ph: 805-4669464 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-NOV-2003 Doc #:07400107
Cust Comments: 03B03 RECALL FOR PEDAL ASSEMBLY
Tech Comments: PERFORMED RECALL PER RECALL INSTRUCTIONS
1FTNW21F73EA13693 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 26-JUL-2002 20-NOV-2002 171472 USA 13 2J88 000615 * NPF * D50 82 22041
AWS Claim Key: 3372186 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 07848 - * Name: ATASCADERO FORD Ph: 805-4669464 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:15-NOV-2003 Doc #:07400102
Cust Comments: VEHICLE RUNNING ROUGH AT ALL SPEEDS
Tech Comments: ROAD TESTED VEHICLE AND PERFORMED DIAGNOSIS. UNABLE TO DUPLICATE CONCERN. NO CODES SET AND ALL SYSTEMS PASS
1FTNW21F73EA13693 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 26-JUL-2002 20-NOV-2002 171472 USA 16 5I01 110204 F1TZ 3A674 DBRM L68 42 23995
AWS Claim Key: 5191404 Trx Code: E84 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 05409 - * Name: JIM VREELAND FORD Ph: 805-6887760 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:11-MAR-2004 Doc #:01631902
Cust Comments: CUST STATES NOISE IN STEERING
Tech Comments: P S PUMP NOISE, LINE LEAKING INSTL NEW LINE AND P S PUMP AND CK FOR LEAKS
1FTNW21F73EA13693 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 26-JUL-2002 20-NOV-2002 171472 USA 16 3A15 070100 F81Z 7G391 CB P59 42 23995
AWS Claim Key: 5160710 Trx Code: S07 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 05409 - * Name: JIM VREELAND FORD Ph: 805-6887760 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:11-MAR-2004 Doc #:01631901
Cust Comments: CUST STATES OD LIGHT FLASHES
Tech Comments: PIN POINT TST INSTL A NEW SOLENOID BODY
1FTNW21F73EA13693 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 26-JUL-2002 20-NOV-2002 171472 USA 21 3A15 070100 F81Z 7G391 CB D50 42 28934
AWS Claim Key: 7286993 Trx Code: S07 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 05409 - * Name: JIM VREELAND FORD Ph: 805-6887760 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:09-AUG-2004 Doc #:01291251
Cust Comments: CUST STATES CHK ENG LT ON
Tech Comments: DIAG CK ENG LITE ON PERFORM TRANS ELEC DIAG W NGS PERFORM PINPOINT TST FOR DTC P1740 FND TCC SOLENOID DTECTIVE REPL AHIFT SOLENOID GROUP
1FTNW21F73EA13693 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 26-JUL-2002 20-NOV-2002 171472 USA 51 7N02 010505 1L2Z 14529 BA G07 42 66438
AWS Claim Key: 14786518 Trx Code: 0858D Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05409 - * Name: JIM VREELAND FORD Ph: 805-6887760 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:10-JAN-2007 Doc #:03436651
Cust Comments: CUST STATES DRIVERS & PASS WINDOWS INOP
Tech Comments: VERIFY INOP REMV TRIM PANEL TO TST SWTICH SIRING BAD SWTICH REPL SWITCH
1FTNW21F73EA13693 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 26-JUL-2002 20-NOV-2002 171472 USA 51 2B01 0300XX F7TZ 12K073 A D02 42 66438
AWS Claim Key: 14790503 Trx Code: E72 Labor Hrs: 1
Dlr Cd-Sub Cd: 05409 - * Name: JIM VREELAND FORD Ph: 805-6887760 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:10-JAN-2007 Doc #:03436652
Cust Comments: CUST STATES ENG DIES & WII BUCK DRIVING
Tech Comments: C ENGINE PERFORMANCE DIAGNOSTICS DIESEL ENGINE DIAGNOSIS
1FTNW21F73EA13693 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 26-JUL-2002 20-NOV-2002 171472 USA 51 2H01 031202 6C3Z 6C640 B D02 42 66438
AWS Claim Key: 14794194 Trx Code: E72 Labor Hrs: 2.3
Dlr Cd-Sub Cd: 05409 - * Name: JIM VREELAND FORD Ph: 805-6887760 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:10-JAN-2007 Doc #:03436653
Cust Comments: CUST STATES ENG OIL LEAK
Tech Comments: ENGINE OIL LEAKS DIAGNOSIS
1FTNW21F73EA13693 T/F7 F T/BC T/BD T/E A1 T/D8 T/DS 26-JUL-2002 20-NOV-2002 171472 USA 68 * * * * * * * 103249
AWS Claim Key: 16021048 Trx Code: 07S57 Labor Hrs: 0
Dlr Cd-Sub Cd: 05409 - * Name: JIM VREELAND FORD Ph: 805-6887760 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:22-MAY-2008 Doc #:04533152
Cust Comments: CUST REQUEST REFUND FOR 07S57 RECALL 29.76
Tech Comments: REEQUEST REFUND FOR 07S57 RECALL
AWS Claim Key: 16018479 Trx Code: 07S57 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 05409 - * Name: JIM VREELAND FORD Ph: 805-6887760 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:22-MAY-2008 Doc #:04533151
Cust Comments: 07S57 RECALL
Tech Comments: C CAMSHAFT POSITION SENSOR INSPECTION AND REPLACEMENT
Reactions: Sleeperstroke
