'83 in the signature needed to remove trans so went back with ZF5 out of '93. used 6.9 flywheel and pressure plate with new RCF 2000 clutch disc from Napa. used alignment tool and saw pressure plate compress while tightening but after installing trans and bleeding slave cyl. the disc is floppy between flywheel and PP. what should I look for? Look to change?
Transmission hitting pressure plate fingers!!!
