Just as it says boys, can someone please explain exactly what "Defueling" is, and how it helps if your EGT's get too high?
You forgot to tell them that when you take away the fuel...you take the power away too. :smoke:Fast-6.0 said:Defueling is basically taking away fuel. Units like the Edge defuel when the EGT's get too hot. More fuel = more heat. Take away fuel egt's drop.
VIZARD said:Well, Johnny boy...you're second definition could also be confused with de GASSING....
Unless of course degassing creates a cascade effect culminating with a defueling episode which then cascades to a derun.
'Cause then you gots de run to de house! LOL
JohnBoyToo said:AaaHaaa...
so YOU'VE been to the same TexMex restaurants we frequent![]()
You don't understand diesel engine combustion at all. Not like gassers. Diesels are stoichiometric.PSDPlayer said:Takeing fuel away will make the engine run lean and create higher EGTs. You would need to retard fuel timing to reduce EGTs.
uh oh, i think you just opened a can of worms...zahndok said:You don't understand diesel engine combustion at all. Not like gassers. Diesels are stoichiometric.
Yes, but diesels don't get hotter when they don't have enough air.. they get colder.PSDPlayer said:Stoichiometric means air fuel ratio of 14.7to1. Below 14.7 you are rich above 14.7 you are lean. it doesn't matter if you are gas or diesel.
Yes, but diesels don't get hotter when they get lean....they get colder. In fact diesels almost never run at 14.7 even at WOT. They would smoke too much. They run at 60-100:1 at idle. They move toward 14.7 as more fuel is added and get to WOT. Gassers on the other hand must always run at 14.7 or they won't run.PSDPlayer said:Stoichiometric means air fuel ratio of 14.7to1. Below 14.7 you are rich above 14.7 you are lean. it doesn't matter if you are gas or diesel.
Hmmm, I know I am new here and I mean no offense to anyone...but, I have just learned that posts can get popped here quickly as well. Must be a contagion about the diesel sites.ISurvivedNMU said:All of us are here to learn, and have fun doing it.. Its our hobby....Brian
