I figured I would start a new thread to get some more attention.
Im putting the GMC on the back burner for a while, I plan on holding on to it for the motor until I can find a good chassis to swap the 7FB into. Until then Im going to be working on my 76 Pete with the 350SC.
The plan is to set the timing to around 80 for the pulling track, then switch what I need to on the top end to work with newer style PTD injectors as well as dual springs off of a 903.
I have an 85mm HT4 that will also be going on it as well, most of the pump work will be done by myself and a few others. We will be shooting for close to 3500-3600rpm under power. It will also get the big N14 balancer.
The only real problem I foresee is being able to get the push tubes to stand up to high rail pressure, I dont think I have ever heard of the valve push tubes failing.
Any one have any insight as to being able to sleeve a big cam injector push tube out to the proper length and making it work, I mean what the worst that can happen, it bends just like the stocker.
Currently the maximum output of the engine I believe will be determined by the amount of fuel we can get injected into the engine. I am in contact with a cam shop that seems willing to work on almost anything, time will tell if I will be able to get the injector lobes modified to something more suitable to compete with an inline pump. :guitar
