weight of fully dressed 7.3 & hand throttel
3.6K views 7 replies 6 participants last post by  KT Performance
#1 ·
Any body know how much a complet 7.3 weighs? I was going to put a hand throttel in my truck, i was going to splice a switch into the harness and mount another TP sensor. I dont see any reason it won't work. anybody done that or seen it done?
#5 ·
I have seen 2 throttles on some intenational garbage trucks with dual drive cab's. I am pritty sure their TPS's are designed basicly the same way as in our pickups. How they worked is they spliced into all of the wires for the TPS except the power wires and run them to the new one. for the power wires they run the wire from the old and new TPS to a 2 way switch, where when you have the switch in one direction the origanl sensor is getting power. then you flit it and only the new switch gets power.
if that dosent make sence I'll try and drawl a diagram or something.
#7 ·
dieslpower97 said:
? Why would you want a hand throttle?
I have BIG plans.
I was going to run the TPS wires into the switch and switch it to run the factory TPS or the one for a hand throttle.
1040 WreckerMan said:
A complete 7.3 will weigh in around 1200lbs depending on the year, but they are all within about 150lbs of 1200.
Thanks
